Headphone amp - low Z load and ... "echo"
They are fed in-phase for sure. A bad contact is not an explanation. Those effects do not exist if I connect 300ohm Senns. I had had similar "echo/chorus" effect with Senns before I changed a coupling cap value to 1uF. I will attach schematics to help trace the bug.
How do you know there is not a contact problem with the 32 ohm phones - have you measured for continuity to all three contacts on the plug??
You provide almost no information about the headphone amplifier and yet you expect a reasonable answer, and when you don't get one you dismiss what under other circumstances would be a very plausible explanation. (I've had phones with a broken ground lead that caused a problem quite similar to your possibly inaccurate description.)
OTOH If this is an OTL design 1uF is way too small a coupling cap for 32 ohm phones - I would recommend a minimum of 100uF and preferably 220uF or more, but I can't be sure without knowing more about the design. The -3dB point with a 1uF cap and 32 ohm load is almost 5kHz which might be why vocals sound so distant, and there would also be no bass. 220uF would give you a -3dB point of about 22Hz.. For acceptable performance with a 300 ohm headphone you would need at least 20uF!
Please post a schematic, or at least tell us whether this amplifier uses output transformers or is an otl of some sort.
Yes, I have measured it. They are ok - I have tested it also with other headphones (sennheiser).
The Phillips HP1000 are also ok - tested with other amp.
I did not mean to be rude and in fact, after I had fired the amp the sound was strange - I had forgotten to connect gnd of the socket! That is why I said so. Sorry for my English.
Find the schematic attached. TIA
The effect described above is exactly what happens when there is no ground connected on the phones. Then everything that is in the center (like solo voice for instance !!!!!) is missing and only the parts that are different between left and right is heard (like stereophonic reverb for instance).
Charles
