Head unit line level output impedance
Yes, gain adjustment is available on everything in the chain (active system). The last two heads I have used had outputs of 2.7v/330ohm (Eclipse 5441) and 2v/10kOhm (Alpine CDA7838) and they didn't have a volume issue. The head I am referencing and asking about here is a Eclipse CD1200. All I can think of as to the lower volume (even with the gain increased) is a impedance mismatch. 55ohm IS a pretty low output impedance.
Even with the gain as high as it will go, it still isn't like the other heads. I'm thinking of using a Audio Control 2XS instead of the xover built into the HiFonics Cyclops monoblock. Below are signal flow charts from before and what I am considering.
