• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
HDI PCB - Higher Circuit Density, Higher Speed Signal
contact: info@pcbonline.com
website: PCB Fabrication and Electronic Components Assembly | Factory Direct Marketing
HDI PCBs are high-density interconnect circuit boards that utilize extremely small traces and vias to decrease the overall size of an electrical design.
HDI PCBs are also perfect for designs where electrical performance and noise rejection are of upmost importance. If you need to design a PCB with a high layer count and micro vias, then an HDI technology is the best solution for your needs.
PCBONLINE provides our customers with the highest quality HDI manufacturing services that can be found.
• HDI designs can easily meet the needs of high-speed signals for improve signal quality.
• These designs offer tighter pitch and thinner traces, micro vias, and an overall higher density of copper connections per square centimeter.
• HDI designs have great impedance control and impressive high-frequency transmission capabilities.
• Significantly reduce the radiated emissions of your circuits, improve the signal integrity of high-speed signals, as well as allow for higher trace routing density.
• Perfect solution for fine pitch packages, flip-chip assemblies, and complicated BGA designs.
• We have a skilled team that is knowledgeable in high-precision via back drilling, quality PCBA processes, and overall highly complicated HDI PCBs.
• We ensure that your product's signal transmission integrity is met by using top-of-the-line technologies to reduce signal series inductance of through holes.
• We utilize a specialized surface treatment process for all of our HDI production lines.
• We have state of the art German machines for V-cuts, tabs, and stack-up management as well as Mitsubishi machines for laser drilling, Hitachi mechanical drilling machines, and processes for automatic LDI and AOI.
• We also utilize the best temperature cycling equipment to ensure that your boards are high reliability and stable over time.
• We strictly follow all current IPC standards and provide you with your completed boards on time.
