Good morning,
I was thinking about using one of those small ARM based boards to use it as a player. Something similar to this project. I was thinking about using a clone of the famous Beagle Board: IGEPv2.
Afterwards, I started about the possibility of running BruteFIR. I spoke with the author about the posibility of optimizing it for ARM, but he is not keen to spend more time on it.
I investigated a little bit further and I found the Hawk Board. It has a floating point DSP running at 300Mhz. It cost around 112$ (74GBP). Looking at the DSP Library Reference Programmer's Reference Guide it is stated the cycles required per operation. For a 48000hz signal it should take around 3 million cycles to perform the FFT convolution (I might be wrong -DSP is far from being my expertise-). So it looks enough to run several filters at the same time.
BruteFIR is amazing, but it looks like it would be enough to develop a JACK client. JACK would provide the infrastructure to do all the connections between filters. In that regard, it looks like it would be a matter of modifying BruteFIR code or jconv just to use Texas Instrument's DSPLIB.
I am not a DSP guy and it is been more than 10 years without developping in C or C++ so I am quite rusty.
Does this look feasible to you guys? Would anybody with much DSP/programming background than myself take over this idea?
Kind regards,
José M.
Kind regards,
José M.
