Having trouble with F3 current source
Hey all.
I'm currently applying power to my F3 boards, and I'm having trouble setting the current source. I understand that the percentage is supposed to be the ratio of current through the output resistor to the ratio through the aleph resitors.
So what I've got, I measuring the AC voltage across resistors R6/R7/R8 (which make 0.4 ohm), and the output resistor R9 (0.47 ohm).
Here's what I get :
drop across r6/r7/r8 = 0.206 V
0.4 / 0.206 = 1.94 A
drop across r9 = 0.35 V
0.47 / 0.35 = 1.35 A
1.94/1.35 *100 = 140 % !!!!!!!!
That's not right ... No matter what I set P2 to, the current through the aleph resistors is alway greater than what's going though the output resistor.
Any idea where I may have gone wrong ?
