Hello everyone!
I am building a phono preamp which requires a +/-15V power supply. I found a schematic for a +/-35V power supply and was told by a friend that the transformer can be replaced with another one and produce a voltage of +/-15V. Is this true? If so, what would be a suitable transformer to use, or else would I need to look for another schematic?
http://sound.westhost.com/project04.htm
Another question I have is in respect to the fact that the power supply is dual channel. If I am building a Minimized GainKlone, would there be a way to power both the preamp as well as the GainKlone with the schematic I have listed above?
Thanks for your time,
-Scott
-Scott
Hi, SideA
Yes, you can change the transformer secondary voltage to get 15V, around 11VAC, but then you have only unregulated voltage... Have a look at:
http://sound.westhost.com/project05.htm
This site is really a compilation of EVERY basic thing you need to know ! 🙂
You could power the regulators from the power amp supply BUT take care of their max voltage input of 35V, it is probably wiser to add a "preregulator" with a zener diode, a resistor and a transistor (a simple series resistor could do the job )...
You may power both preamp channels with only one +/- 15V regulator, as the currents should be low.
You also may use better regulators such as LM317/337 with a few extra resistors...
Hope this helps
Hope this helps
