The ****** is eluding me. Anybody know where to get both?
it is a cdm150/t6/sa g12 socket 4200K. Im at a standstill. Produciton advantage has the bulb but has no clue about a ballast.
Thanks,
Jarrett
Thanks,
Jarrett
you betcha. ;-)
what made you decide 150 cdm-t over 250 MH? I'm trying to decide between the two for my 7" projector as well...
wish I could afford both so I could see the difference...
ace's advice and bulb price! I will have $120 inmy light ballast and socket, not bad i dont think.
I'm soliciting ace's advise as well... what did he say that convinced you?
I ask because that cdmt ballast is magnetic. From alan at diy, the 250W ballast/socket/bulb is $150, and replacement bulbs are $30....
I'd like to have the quieter, more energy efficient eletronic ballast.
I wonder if the 250 is just too much light for the 7"?
Well, I trust ace's construction over everything else i've seen.
Any other supplers for that g12? It only allows me to choose singapore as an address!
shoot...that's the only place I've seen for that base.
You might try the hello lights website. I'll look around when I get some free time, if you don't post that you've found it already
I was planning to order from them. that sucks. wonder if an email would work? maybe they'll ship to the states if you ask?
Write to Neil at production advantage:
neillb(at)proadv.com
The G12/3801 with leads is available at $7.80 each.
They have a $25 minimum order, but they can get the bulbs and ballasts too.
http://www.productionadvantageonline.com
im waiting on the to call me back and tell me if they can evenget the bulb. Hope so, ill get the socket there too. Good news my lcd is in town out for delivery now!
Bad news. The bulb is on indefinite backorder. Any help? I am going to try to cancel my ballast order now.
THanks,
Jarrett
THanks,
Jarrett
they should have that bulb in stock...I think it's $42 or so though. on the bulb link I posted search for "150" or "cdm" and you'll find the section. they have several different bulbs.
oops...just saw your post...that sucks. I talked to them last week and they had them...
when I spoke to them, the couldn't get ballasts though -- what do you know about their ballasts brainchild?
Here's what he wrote:
I've done some research and come up with two ballasts that my
distributor has in stock. They are both rated for the CDM150/T6/942
metal halide lamp. One is a dual ballast and the other is a
quad/multi-tap.
Part# Description
Unit$
71A5482 Dual M-H ballast, 120/277V, M102/M142 $148.35
71A5492 Quad M-H ballast, 120/208/240/277V, M102 $135.45
quad/multi-tap.
Part# Description
Unit$
well, here are three links, but they don't get very specific about the bulbs...might be worth an email though...
http://www.thelightsmith.com/catalog/product_info.php?cPath=26&products_id=278
http://www.discountdjmall.com/index.asp?PageAction=VIEWPROD&ProdID=767
http://www.lighting-effect.com/cgi-...s/op=rm/nu=0/ml=9999/tf=description/to=x.html
Brainchild -- what happens if you power only one light from a multitap? Is that up to 2 or 4, or requires 2 or 4 lamps?
I won an auction on ebay.de. should have it here in next week or so. they are running from 5 euro - 20 euro normally, letter post shipping about $6 to US. but 942's are harder to find.
I suppose you can use normal 150 MH ballast for CDM-T bulb. M81, M102, M142 are all OK.
- General Interest
- Everything Else
- The Moving Image
- Lighting and OHP
- having the worst time locatig the cdm-t g12 socket bulb and ballast. Any help?
