Read this post# 868:
From reading the above, how much certainty is I think I hear differences? It is done a few seconds after download.
And here is post# 1098 BigE was responding to in his quote:
I'm the only one who knows how much differences exist between these 2 computers. And it is BIG. So big that it is equivalent like saying I know that my wife is talking even without seeing her lips. It is so BIG that with all my consciousness I will put my $1000 for your $1 if I possibly made mistake in my judgement.
Remember the Media Player Classic screenshot showing a "broken" screen? That is part of the problem. Video has problem (which is obvious to everyone) as well as audio (which is not obvious to everyone, but obvious to me).
Just downloaded the player 🙂
I didn't check the setup options but it seems it has more "information" in the music than Foobar. More non-musical background information on MM, probably because the SPl/gain is higher. But I think piano sounds more "rich", more like piano. I don't know if it is a hallucination, just describing what I think I've heard 😀
From listening alone I know that my computer is not "bit-perfect". Sorry to use this vague terminology. Where the problem lies, is not something easy to find... But if I were paid to find it, I will find it... It wont be difficult, just boring and time consuming...
You will ask, how could I know that my computer is not "perfect" without hard evidence? Coz I trust my ears more than you trust yours or mine... I simply notice how the same file sound different in different computers (both using Windows XP)...
False dichotomy - what's the product of the bias is just as real.
No. Delusions may seem real, but they are still delusions.
I once read about a "test" where a switch was installed and marked with two positions: SS and Tube. Two amps were visible, a SS amp and a tube amp. Only the SS amp was functional, although the heaters did glow in the tube amp.
When people switched from SS to tube, and back, they commented how sterile the sound was when switched to SS, and how warm it was in tube mode.
Is that how we should proceed with this hobby? Should we accept people fooling us into believing that what they offer is substantively better without any formal testing process?
At least one group is trying to control companies from misleading the public:
https://www.asa.org.uk/Rulings/Adjudications/2014/11/The-Chord-Company-Ltd/SHP_ADJ_274211.aspx#.VYyzivlVikr
Go watch the vid.
In sighted listening it is possible that the difference you are hearing between two bit perfect streams is real. But probably not, and we are safe in the knowledge that no difference exists. So your analogy supports MY position, not yours.
So you were quoting other people words without genuine interest in what those words are saying, only as a vehicle to bring forward your own ideas/opinion which is often unrelated?
BTW, who is hearing differences between two bit perfect streams? A noname? But I don't understand about "position".
But thanks for the English lesson (about the difference between possibility and probability), I hope it is accurate as I wont recheck with wikipedia or wikitheasurus 😉
It is interesting to see how many subjectivist only use there ego to judge equipment. Why are so many afraid of double blind testing.
It seems like I don't belong to that group you're referring?! At least I'm not afraid of blind tests. A few groups had invited me if I could hear the effect of "exotic" stuffs and upgrades. With surprising result 😉
Even double blind testing dosnt tell you what's more accurate just what's more preferable.
Even preference is not that simple. If people mention what they prefer, without 100% accuracy in picking difference, you can ignore that data.
Even with 100% accuracy in picking difference, preference is only relevant if it refers to other/previous firm experience.
And after years on this web site I've come to realize, what's more preferable for most "audiophiles" is some sort of distortion.
The way I look at it, is the "basic" lesson I have learnt as a beginner, hanging around people with the same audio hobby. There is this "big" mantra called MATCHING...
So it's about the whole chain. If our CD player is BRIGHT, we will prefer our amplifier or speaker to be DULL. That's the concept. Still being used by Stereophile reviewers...
So it doesn't mean that we prefer DULL speaker. Just when we have the option only to change the speaker then that is what we prefer, a DULL one 😀
Same with second order distortion, speaker panel vibration, early reflection, etc. We only care about the "final" result.
Well, I could point to all those that say that different media players which eventually cause identical bit streams to be fed to the DAC, must sound the same, 😉 - ignoring the fact that the electrical environment of the converter and associated analogue circuitry may be subject to different levels and patterns of interference and noise while this streaming is occurring - I assume nothing is a "must", which has helped me enormously over the years, 🙂.
And tell me now precisely what this has to do with " one element has a brilliant set of numbers, from one set of technical tests, then it is now 'transparent' "
I never referenced any set of numbers from a technical test, and did not claim anything to be transparent.
Try again. Tell me just how I fit into the mold of how you imagine an objectivist thinks.
Knowledge and understanding computers is not inextricably linked to whatever it is that you think exemplifies "objectivist" thinking. I, for one, do not put a lot of emphasis on the numbers themselves. I do not blindly believe that more is better.
What I do know is that the less interaction, the less bit mangling, that software does to a stream of digital audio, the better. I also know that software bit mangling has far greater potential to degrade audio reproduction than the miniscule (if at all) variations in signal noise inside a PC due to the use of one player as opposed to a different one. And finally, I know that it is a trivial matter to rule out the software bit mangling.
Frank, you can go on and on trying various players and clicking random features on and off again, but until you take steps to ensure that the players are not mangling the bits, the miniscule possibility of different PC "noise patterns" from one player to another remains completely irrelevant.
You won't believe me, of course, or agree, but the difference you are claiming to hear is almost certainly directly due to the fact that the bitstreams from the files are not making it to the audio chip unscathed. Data integrity is not being maintained.
Once this issue is worked out between the OS and player(s), then perhaps it may be worth it to pursue your noise pattern theory. I do suggest investing in some very sensive equipment to put that theory to the test. You are going to need it. And yes, I know this will never happen.
In the meantime, I'm going to buy a cat.
Jay said:(1) Anything can happen in software and computer processing. So that nothing surprising if (2) Players sound different (they do).
So, if two players are configured to produce bit perfect results, they will sound different?
Done. How does it apply?
Its about how perception works - you noticed that right? Or do you think visual perception is something different from audio?
You better buy SY's cat so you don't need to waste your time teaching her Calculus 😀
We've done this conversation to death. Some members here are immune to logic.
Right. I shall begin by teaching her logic.
Let me be more clear: What do you think it says about audio? And how does that relate to objective proof (if it does at all)?
Do you wish to persuade people? Then you might begin with the insight that its not logic which persuades, rather reason.
Plenty of books on Amazon explain this, you could do a search on 'persuasion'.
I have no opinions on it, but a few observations. Do you want the latter?
You used the word 'real' in that post but what did you mean by it? If you'd explain that then perhaps I can tie up between your explanation and what Hoffman's saying.
You suggested false dichotomy as if you knew what you were talking about. And you directed me to Hoffman. I want to know how Hoffman's talk supports your idea.
Are you thinking that SY wouldn't have taught her well on logic?? Just teach her gently, she might have interest in different subject...
- Member Areas
- The Lounge
- Have you discovered a digital source, that satisfies you, as much as your Turntable?
