For Sale Hashimoto HW-60-5 pair (EU)
Things you have for sale.
I am selling one pair of Hashimoto HW-60-5 Push Pull Output transformers.
Excellent condition, in original packaging.
Asking 630€ PayPal F&F, The transformers are in Denmark, will ship worldwide.
“The Hashimoto HW-60-5 is for applications that require the 5K Ohms primary with up to 60 Watts output level into 4, 8, 16 Ohms. The HW-60-5 is equipped with an Ultra-Linear tap, and its frequency response covers between 10Hz and 70,000Hz (+-3db). The HW-60-5 is suitable for high-powered Push-Pull applications that utilize popular vacuum tubes, such as 300B, KT-88, 6550, EL34 (6CA7), and 6L6-GC.
The HW-60-5 measures 100 (W) x 110 (D) x 120 (H) mm, and weighs 4.1Kg (9.0 LB). The Primary Inductance is 200H and the Maximum DC Current can be up to 125mA x 2. The HW-60-5 utilizes a twin Cut-Core, and the core material is 0.27mm Orient Core Hi-B which is the enhanced directional silicon steel, from Nippon Steel Corporation.”
