Has anyone tried a 6S4A as a 300B driver tube?
6s4a is my all time favorite driver tube for electrostatic
headphones. As a 300b driver it should work well, but the
extra voltage it is capable of is very much wasted on a 300B.
2 sections of 6sn7 in parallel has more drive capability and the
300B really wants that when you go into positive grid drive
current.
2 sections of 6sn7 in parallel has more drive capability and the 300B really wants that when you go into positive grid drive current.
Parallel triodes aren't exactly paradise either...
The 6S4 is the predecessor of the 12B4, plenty of juice to drive a 300B, I reckon.
Cheers, 😉
Propsed Circuit
The input stage is a 6922 yet to be drawn.
Here is my proposed driver.
The output is a 300 B into a 2.5 K SE transformer.
Any comments.
Has anyone got the tools to simulate this circuit before I build it?
Any of the experts out there have a simulation tool that can handle this circuit. 😕
I would like to assemble this weekend if it looks feasable.
The current sources will be a Supertex Enhancent mode FET.
Power Supply and a 1 minute delay circuit for the B+ are complete and tested, I will draw them out over the next few days.:wrench:
Hi MikeT, did you ever build this amp?
I like the 6s4a (I have an amp using 6s4a as power tube and it sounds great). I also built a 6s4a WOT preamp and I like it.
Am thinking of building a 300 SE with 5687 input tube and 6s4a as driver.
What do you think guys?
6S4 is a good looking triode, but is designed for 150V operation, and a limit of 160V.
Meanwhile the 300B is normally biassed at -60 to -80V, and to allow some margin, the driver must be able to swing +/- 100V. With anode voltage = 150V idle, 6S4 can manage the negative swing, but going +ve, the curves become obviously nonlinear above 200V or so, even if CCS loading is used.
Only high quality option is to try a series cascode, which is what the tube was designed for. IME, an NPN transistor in the upstairs position is best here.
