Has anybody played with ...
Check out slim,cheap,mcm towers.It show fre.res.graph on 55-1200.# 55-1200 WOOFER 4.5" MCM POLY PAPER
Size 4.500 IN RMS Watts 40
Mount Length 3.400 IN Peak Watts 60
Mount Width 3.400 IN Frequency Rsp 60-10KHZ
Mount Depth 2.400 IN Imp/Ohm 8.00
Cutout Diam 4.125 IN SPL (db) 94.00
Free Air 83.00 HZ
Magnet Weight 10.000 / OZ QES .802
Magnet Diameter / QMS 3.500
Voice Coil Diam 1.000 / IN QTS .650
VAS .140 CF
Le.33mhz
Cone Material TP TREATED PAPE RE
Surround Material BR BUTYL RUBBER XMAX 2.000 Thank you,
MCM Tech Dept
