has anybody heard one? i wonder why such a simple circuitry did not become popular?
pretty obvious if you look at the o/p tube and it's availability / price and the o/p power that can be excpected from one which if my memory serves me right is miniscule even back in the days of sound practices they were a right rare tube to get even used the price was pretty substantial [ if you could find one!] cheers TC
Re: can this be scaled up?
No go! You can use voltage regulators in series, but not in parallel.
Ralf
AudioGeek said:what is the possibility of it being scaled up to say a 300B circuit using parallel VR tubes in the cathode?
Ralf
well if you can find some used 45's at a reasonable price, it is a very simple circuit and using the hammond 125 e op xfrm it may be a nice and simple amp to build BUT I would use the hammond 125 se as being a better choice and by all accounts performs quite well in 2a3 se circuits. cheers TC
Konnichiwa,
Not directly, but by combining a VR Valve AND something like a KT88 you can make a "power shunt regulator that keeps the voltage on the KT88 Anode quite constant. Then apply a choke with an apropriate series resistorto load the driver and bias the output valve, voila, done. But a resistor/capacitor parallel combo in the output cathode will do not really any worse, if the capcitor is high quality or perhaps WE/UP connection is employed.
Sayonara
Konnichiwa,
Sayonara
Surely it is a bit dangerous to run the 45 tube with this direct coupled configuration.
I would prefer running it with the RC coupled and it is almost fail safe.
I believe the VR might cause some more noise and distortion in comparison with cathode resistor with bypassed capacitor. Just a guess.
Johnny
Johnny
rdf said:Also, as drawn the VR tube is within 4 ma of its maximum current. Wouldn't the 0D3 would be operating well outside of spec at anything above very low output levels?
i thought i saw someone else raise the same concern on another forum.
thanks
- Tubes / Valves
- Has anybody built the Matthew Reidsma Experimental 45?
