Harristech Bassbox 6 pro and X-Over3 pro with Windows 10?
looks like my image hasn't worked. Here's the info:
Driver Properties
Type: Standard one-way driver
Company: JBL / Harman Consumer Group
No. of Drivers = 2
Mounting = Standard
Wiring = Parallel
Fs = 28 Hz
Qms = 8.85
Vas = 2.7 cu.ft
Xmax = 0.25 in
P-Dia = 12 in
Qes = 0.57
Re = 3.6 ohms
Z = 4 ohms
Pe = 250 watts
Box Properties
Name:
Type: Bandpass Parallel Double-Tuned
Shape: Prism, Bandpass
with three chambers
Chamber 1 - lower-freq.
Vb = 190.6 liters
Fb = 30 Hz
QL = 5
F3 = 33.05 Hz
Fill = normal
No. of Vents = 1
Vent shape = rectangle
Vent ends = one flush
Hv = 50 mm
Wv = 385 mm
Lv = 243.6 mm
Chamber 2 - upper-freq.
Vb = 135.2 liters
Fb = 60 Hz
QL = 6.141
F3 = 73.92 Hz
Fill = normal
No. of Vents = 1
Hv = 50 mm
Wv = 520 mm
Lv = 59.28 mm
Chamber 3 - lower-freq.
Vb = 190.6 liters
Fb = 30 Hz
QL = 5
F3 = 33.05 Hz
Fill = normal
No. of Vents = 1
Hv = 50 mm
Wv = 385 mm
Lv = 243.6 mm
I'm trying to create a 'slotted' vent design with all ports at the front at 50mm (2")
