Harmon Kardon A401
Hello Everyone.
I have a Harmon Kardon A401 integrated amplifier. I bought it new in 1976. Later I sold it to a friend who returned as junk a few years ago. I replaced all the electrolytics and the output transistors. It works again and sounds alright. My question is if I replace the small signal transistors with up to date versions will it sound better? Or is it a waste of time and money? I've attached a list of those transistors. Most are no longer available so I would have to find substitutes.
Thanks, Kevin
Most of the time the 'glue' is there to mechanically stabilize the part. Electrolytic capacitors tend to be a bit massive, and gluing them to the board helps prevent mechanical stress failure of the leads. But leakage is certainly possible.
