If you truly do not understand why is better to have few hundred times lower impedance, I really can not help..
I suspect you can come up with a better argument?
I do not need better..
All this back and forth yammering about MM vs. MC has only served to dilute this thread, which started out as a question of the relative merits of various "entry level" MC cartridges.
I never even considered getting an MM cartridge, as one of the reasons I'm setting up for MC is so that I can start developing some MC preamps. Having said that, I'll do initial listening with the step-up transformers I have on hand.
Last night, I pulled the the trigger and bought the AT-OC9ML/II - the price was too good to pass up. It won't be the best cart in the world, but it'll most likely soundly kick butt on everything I currently own (old Sumiko Blue Point, Grado Gold). I also have a Denon DL-160 still in the box. Before I try the low output cartridge, I intend to swap the Denon into my system and check out how it performs with several of my preamps.
Last night, I pulled the the trigger and bought the AT-OC9ML/II - the price was too good to pass up..
Congratulations..
After Ortofon Salsa, which I understand is no longer in stock, the best pickup in this price range..
Last night, I pulled the the trigger and bought the AT-OC9ML/II...
It's a very good cartridge and was on my short-list before I opted for the 150MLX.
Run balanced!
Coincidentally, this happened on another forum recently regarding the AT33PTGII. One particular member decided that his Naogoka MP-500 was the greatest thing since sliced bread, and the AT33PTGII couldn't possibly be better. Most of the posters just ignored this particular member. In the end, the OP bought the AT and couldn't be happier.
jeff
On the other hand, if you are so clear about it, you could please explain to us in a few words? I really don't know why it is better.
BTW I have a Salsa.
Jan
OK, so my conclusion would be: 'I, Vulejov, read some posts about this 10 years ago or so, but I really don't understand the issue, so I can't explain it'.
Is that a fair assessment?
jan
OK, so my conclusion would be..
I really do not care about your opinion..
Here's a link that explained a bit.. Hagerman Technology LLC: Cartridge Loading
There is also MM cartridge loading - not all MMs sound best at 47K.
Andy
Perhaps you should. This link and apparently your thought process are missing part of the equation- this is an electromechanical transducer, and the Hagerman link only accounts for the electrical part. The actual frequency response is the product of the electrical and mechanical response.
If you have a copy of Linear Audio Vol 7, note the analysis in the Equal Opportunity article, especially Figure 3 and the paragraph above that. With correct loading, a good MM cartridge has excellent frequency response, and the best MMs have an extended response that lacks the HF ringing which is a "feature" of nearly all MCs.
Don't confuse the issue with technical facts. I've been following this with interest since someone droped my TT and arm on it's head while in storage I had to start over. I am in the process of rewiring a Thorens TD-160 for differential which I found on the cheap. Lots of good cart recommendations here.
- Analogue Source
- Happy B'day to me - MC Cart Suggestions
