Joined 2002
karma said:looks nice, im stearing away from using plastic water line😀
better left under the sink😱
kinda like the last set i got off of you, so stiff i need to keep the stereo cabnet 5 feet away from the wall. so thay dont scrach the paint off the wall. you used air line on that set. i like my cables
soft😉
That cable was a test cable. The line it not air line it is Water line with a thick base. It's bought for water lines in your house. The new stuff i use is thiner and way softer.
Joined 2002
karma said:im using flat Extruded FEP 😉
i have somthing that would look good with that test cable😀
just kidding😉
cheers
Are we working against or together on this ?
together have a open mind😀
i have a set of rcas finished when the wife gets off the other pc ill post a pic.
im sure you will like them hand made is always the best.
Joined 2002
Joined 2002
karma said:ill send you my number in the morning😉
Here are the connectors im going to be using. Better cable's better connectors. We need to work together. Also i work all day tomorrow 🙂
Joined 2002
karma said:no problem, ill talk to you when your finished work. i work in the morning also.
im leaving in the morning to pic up a cigar box😀
Hey don't buy one. Buy more than one 🙂
HGA is where i get all my connectors because i get dealer price's 🙂
The wire they sell IS so nice..Good people too. Order is on it's way at this moment.
Joined 2002
Joined 2002
karma said:when i get paid im picking up a new Hand Held Oscilloscope and a new volt meter to replace my aging units, i need to tap them on the table to get them to work properly😀
still need to pic up a cigar boxs, i was to bussy last night😉
How much for that handhelp scope ? I was thinking about getting one so i can do simple stuff but i might just splurge and get a niceer one then a nice desktop psu 100$
$172 canadian and up. personaly i would like to get the one with the free bag
http://store.qkits.com/category.cfm/TEST
lucky me the place is close to me. ill be buying a few things to play with.
Joined 2002
karma said:$172 canadian and up. personaly i would like to get the one with the free bag
I dont know if that hand held scope will be fast enough. But i have a digital pre-amp that i bought from them
http://store.qkits.com/moreinfo.cfm/K4100
I'm selling cheap as i never use it.. Paid over 500$ for it. Want it ?
Joined 2002
karma said:
Make me a offer..
And that tube kit is not that good had it..
I'm actually bhuilding a tube pre-amp i'll send you a set of board's.
- Design & Build
- Equipment & Tools
- hanging up my soldering iron
