Hammond 273BX is smoking after putting it in the two diode center tap arrangement
OK, but what are you trying to do with this arrangement? To test a transformer and the rectifiers, you need to pull 50%-75% of its rated output current. So that's over 50 watts. If you only load it with 1mA, the transformer could produce as much as 25% higher voltage than the rating, and that would rise to a peak voltage over 600v.
His power transformer is already damaged from him using a 1k load resistor and drawing over 400mA when the max. rating is 200mA.
When a power transformer is smoking, the insulation on the secondary windings is certainly compromised.
Reactions: kevinkr
If you are going to be designing and testing then do yourself a favour and get a dim bulb tester, is a must, in most instances it will prevent damage to components/transformers etc in the event of an error in wiring, schematics or accidental shorts due to mistakes or poor construction techniques, and when you do make a mistake (we all make them) the dim bulb tester might save the day - if you are not sure what a dim bulb tester is, google the term, there are plenty of examples/videos on line for you to follow. Don't be tempted to power up the circuit until you have the dim bulb tester in place, take extra care in making one, it is connected directly to the mains.
Now for some constructive criticism:- the photo you posted gives the impression that you haven't had much/any experience at breadboarding/constructing a circuit - it all looks pretty woeful, almost like you are asking for trouble, however we all need to start somewhere, and I'm sure things will improve as you gain experience - I suggest you troll through as many forum posts as you can looking at pictures, of other peoples work - see how they do it - watch some youtube videos - practise your soldering techniques - invest in a turret board, they are cheap and plentiful on sites like ebay, it can be used over and over - with a turret board your components are safely anchored, the circuit is easier to follow, you can draw out a pictorial of the circuit on paper and double check it is correct before wiring and powering up. If you don't want to invest in a turret board then a few rows of small brass wood screws screwed into your particle board will also work, keeping the wiring neat is an advantage when it comes to asking for help on the forum - forum members will find it easier to spot errors when it comes to photos.
Thanks for your helpful critiques. I learned breadboarding/building circuits in a weird way. I can read schematics and place components as they appear on schematics or designs but I fall short when it comes to EMI, pcb design, and component placement which I know I need to work on. I am also doing the best with what I have. I’ll get a dim bulb tester and variac as you say would help with my testing. I plan on doing these amps as not only a hobby but something I plan on making business from.
Wait, so you’re having trouble wiring up diodes for the power supply, and you want to build a push pull parallel tube amplifier of your own design, as a first project?
Please don’t take this the wrong way, but you need to slow down, back up, and start with something simpler…. if not, this could end in disaster.
I’m not trying to rain on your parade, but this is not a simple task. It’s also got deadly voltages and chances of success without the proper tools and testing equipment are next to zero…..
I recommend Morgan Jones, volume 4, give it a read, it’s worth its weight in gold😎
I know this isn’t a simple task but I know basic electricity. I also know the working on push pull amps on the transistor level.. which means they should work similar at the tube level. Trust me, I know these are dangerous voltages lol. I have been working on this project for over 1 year now, have been tapped by the HT a few times, but I haven’t died yet, now I know a little better about electrical safety while working with tubes. Please know I am not doing this out of random. This is the ultimate test of my knowledge and I know it is difficult. I have done my loadline calculations, filters, power supply tap calculations.. it is just a lot and I am trying my best to make a good product.
This transformer model (and do not use this specific transformer in a finished amp!) is really adequate to power only a single channel at your proposed 150mA. Most of that power will be consumed by the EL34 output stage. You are asking for trouble if you expect an EL34 to dissipate much more than 20W on a continuous basis so this is about 100mA for a single pair at a supply voltage of 400V.
My rule of thumb for power transformer life is the maximum DC load current should be <70% of the transformer AC rating. Many will recommend 50%. I built tube power amps commercially in the distant past and replaced power transformers that shorted due to overloading. (I did not follow the above rule initially.) Generally the HV secondary developed a winding to winding short, but I also saw a couple with shorted primary winding.
