Holding the input constant what is the worst case oamffset (drift)?
In this example, it is approximately 50mV (Q1 and Q3 held at the same temperature).
It depends on the matching of the current densities in Q1 and Q3. If the currents are scaled in the same proportion as the junction areas, a first order cancellation occurs, both statically and dynamically.
Have you built and auditioned it?
Yes, I have built it, tested it with real audio too: no obvious flaw.
I won't comment further in that direction since I have tin ears, but it sounds OK.
It is not a topology for the faint hearted though: the input impedance is negative, which can be disconcerting to the novice.
Joined 2009
Or this way too, could hold those two emitters constant.
You might ask, why not a simple mirror across the top?
Yeah, but a mirror isn't so easy to bootstrap. Or is it???
M2 might want gate swing a few volts above the rail.
I keep trying to throw a gratuitous Taylor in there,
other weird solutions just keep popping in my head.
At least we are watching a collector and bouncing
that info as current to an active load on the emitter...
- Halve the diamond, double the performance!!!
