Hall-effect current sensor for output stage over-current protection
I am considering to use a hall-effect current sensor such as ACS-712 (http://www.allegromicro.com/en/Products/Part_Numbers/0712/0712.pdf) to protect amplifier output stage. The resistance of the copper conductive path of ACS712 is just 1.2 mR which is effective zero resistance in the intended application. It is also electrically isolated from other part of the chip. The output analog signal can be used to drive a relay circuit or sampled by ADC of an MCU.
Since the conductive path is just a piece of copper, it should not introduce any distortion. Although the chip employes chopper stabilization technique, the electrically isolated path should not be picking up any interference. Well, it might via capacitive or inductive paths.
Any comment?
More than ten years ago I did similar current sense-protection, adjustable to any current-trigger level as needed. It works perfectly till these days. ;)
