Half Bridge SMPS series Capacitor selection
Their is one rule.
Use as enormous capacitor as you like...the bigger the better.
However, the bigger the more expensive.
So therefore, use as small as you can get away with.
As long as the capacitor can handle the ripple current in it, then you are fine.
So, get on the simulator eg ltspice, and keep reducing the cap value until you see the normal half bridge waveform "curling over"
when it start to curl over, that means that the capacitive reactance is offering a impedance to the power flow, at the switching frequency.
A bit of "curl" is ok, but not too much.....i usually just get it so that the waveforms just loose their edgyness, and then stop there....but often , i then have to increase the cap value from this in order to handle the ripple current.
There is a formula for it... Coupling capacitor size in microfarads is given by primary peak current in amps times maximum on time in microseconds over permissible voltage drop.
C = Ipk * Ton / Vdrop
Remember that the voltage drop of the coupling cap affects the voltage going into the transformer, with the average voltage the transformer sees at full load being the mean of the input voltage and what's left of it after you subtract the capacitor drop. Voltage drops of 15 to 30 volts are permissible.
The cap provides a safety factor with excessive loads or core saturation. The cap will limit the amount of current passed through the transformer with a fixed switching frequency. The cap will only permit a fixed amount of energy to pass through the transformer per switching cycle.
Typically when testing new designs its good practice to under-size the switching cap so you can evaluate your circuit without blowing up the switching transistors if there is a problem (ie core saturation, problem on the secondary side, etc). Once an initial assessment is made, the cap is replaced with the design cap size.
Also note that you need to use an AC cap, not a polarized cap. Cap size is also dependant on switching frequency. The higher the switching frequency the smaller the cap size is needed to meet output current capacity. Other cap parameters to consider is ESR (which can change depending on switching frequency. Most datasheets spec. ESR at 1Khz, which is likely below your switching frequency). Caps with high ESR will impact energy transfer and the efficiency of your Power supply.
