Not sure if this is the right place, but here goes.
I was finally able to track down a PCB for a Clarinet. I have had the majority of parts to build one for years and Jim stopped selling the boards right after so I never built it. Two of the capacitors he had in the BOM was a Murata DE2F3KH103MA3B ceramics. One goes across the the AC right after the fuse and the other is in series with a resistor across the 5Y3 AC. The KH versions seem to be obsolete and I’m looking for suitable replacements.
I think that the Murata DE2F3KY103MA3BU02F would work, but I’m not familiar with X1,Y2 safety resistors.
They are C100 and C101 in the schematic.
Any help with finding a suitable replacement I would appreciate!
Just keep about the same value, and keep the same voltage rating.
Also keep an X type as X, and keep a Y type as Y. Otherwise the choice is not too critical.
Just keep the same voltage rating, and keep X as X type, and keep Y as Y type.
Otherwise the choice is not critical if they fit mechanically.
Thanks. Looking at the data sheets it looks like the only difference is the KY has a 300VAC rating and the KH has a 250VAC and the insulation breakdown is above 2KVDC for both. Both are X1/Y2. The KY is 25% smaller in size.
