Hafler TA1600 recapping... looking for more bass
The 10uF/16V electrolytic capacitors (C21 and C22) on both channels were bad (pF range). Swapped both of those out, the amp works perfectly now.
I am going to change caps on a 1600. I cannot see the C21 and C22 caps..? I see the 10uf 16V caps - but none of them are labelled C21 or C22 - can't see C21 or C22 on the board - I am looking at just one channel - could they be on the other board for the other channel?
Thanks for the tips. Yes I will change all the caps and I am good with changing the larger electrolytic - it was the small v-chip style I have never done.
Did you replace the v-chip style C21 and C22 with a regular electrolytic cap. of the same rating? If so I wonder how you got them soldered on the board?
And thanks again for resonding.
