Hafler DH200 transformer specs
I have a "salvaged" Hafler DH200 and I have searched but have not been able to get a reliable specification on the Transformer (this is not the international version).
From what I have read it appears to be a 40-0-40 of about 480 VA (or about 6 amps).
If so I am assuming this would give about +/- 55 or 56 volts on the rails.
Does anyone know if I am in right ball park?
My eventual goal is to see if this could be used in building a Leach 4.5 stereo amp.
Thanks!
djk said:
40-0-40 only gives ±57V, the DH200/220 are ±63V.
With a Leach type amplifier it will clip at about 300W/4R.
Thanks for the replies.
So it looks like my the transformer on the Hafler DH200 is 44-0-44
with voltage on the rails at +/- 63V.
The transformer that is suggested on the Leach website is 80V AC, (40-0-40) and having rail voltages of +/- 58V.
So I guess my question is how close is 58V to 63V? Is this difference okay with a proper choice of transistors? Or am I worrying too much?
As far as the overall power before clipping, I can live with 300W/4R since this is being used for a horn loaded driver.
I noticed when BrianGT built his Leach in a Hafler chassis, he used a new transformer (40-0-40).
You can use any voltage with enough outputs.
The Leach LSR&D 101 used three pair of MJ15011/12 on ±63V and could drive 2 ohms on music.
I have done six pair of MJ15024/25 on ±93V on 4 ohms, and ten pair on ±80V on 1 ohm.
the Leach will work on 40Vac or 45Vac.
The bigger expense is that 63Vdc caps can only be used on transformers rated to <=41Vac and only if the mains has <=6% tolerance for overvoltage.
My 230:40+40Vac toroid gives +-58.2Vdc (total Iq=420mA) from 240Vac and gets 311W into 4ohms for the 3pair Jens' PCB design.
