H2 Generator
Hi Nelson. I want to build my own version of your H2 generator, since I was not at your Amp Camp😱 I have all the parts in stock, including the J112. In the documentation you said they need to be matched for a pinch voltage of 2.0 to 2.5V for an IDSS of 30-40ma. Is it an error there since the J112 IDDS is about 5ma from the specs sheet, or I'm missing something?
SB
Hi. Finally saw that into the article it is explained, my error. Was reading it last night, too late I guess. Sorry for my stupid question 😱
But I still think that the article should mention 3-4ma and not 30-40ma 😉
I am using Vp of 2 - 3 volts and selecting parts from that population based
on the supply voltage in the circuit. The H2 can then be adjusted by the
supply voltage regulator. One regulator means matching requirement.
The DIY H2 coming up has two regulators, independently adjustable,
and the Fets are supplied with calibrated voltages.
:wiz:
