just guessing on the H100 = hoping for lots of room gain and the front brings up an area where it may rolloff - does this sim look close enough in general ?
(using William Cowan's Horn sub Jr. corner effect flattens response nicely to ~40Hz)
what driver is used in H100? - I grabbed the specs of an inexpensive Tymphany 12 for the sim below
it might perform very nice (love to haev one) - I'm trying to find either simulation or measurement of the H80 or H100
would a cardboard tube be too weak ?
- H-100W 30cm horn driver"
Thiele-Small Parameter (exept Re all data at both voice coils parallel = 2 Ohm)
Re = 3,9 + 3,9 Ohm, Le = 0,50 mH, FS = 25 Hz, Qms = 10,81, Qes = 0,754, Qts = 0,70, Sd = 509 qcm, Vas = 193 l, Mms = 90 g, BL = 8,12 N/A.
- Bildergalerie H-80 Eckhornsubwoofer"
- Der druckvolle H-100 Eckhorn Subwoofer"
- Subwoofers
- H frame tips to match Klipsch Heresy
