I want to build a f5 turbo v2 for my front stereo speakers but I don't know what to do with my center channel. do I need to use the same amp for my sound stage. what do you guys recommend? can I build a f5 t v2 mono block with the same wattage or would i be okay with a v3? what i'm worried about is using a different amp set up and coloring the sound.
thanks for your advice
Brandan
Brandan
when HT is in case, I wouldn't worry about that level of verity , to have same amps all the way
anyway , if it\s F5 , they're all sharing same character , as long you don't fiddle with P3 too much
thank you for the info. do you think i would be better off going with 3 f5 t v3 mono blocks or f5 t v2 and a f5 tv3 for the center?
how could I answer that , without knowing anything about your setup?
if you wanna play safe , make 3 identical channels
If I had three chassis/enclosures that suited a mono-block, then I would build three mono-blocks and locate each at the speaker's terminals with very short speaker cables.
This avoids many of the pitfalls that afflict builds.
If all the speakers are full frequency range, then all the amplifiers will be identical.
