That's plain WRONG! Do the math. On the typical 4-8-16 ohm winding, the 4 ohm tap is the center tap.
Pick any power level. Calculate the voltage using the formula V=SquareRoot(P*R). 16 ohms gives twice the voltage that 4 ohms does.
Perhaps I've been having a 'senior moment'? 😱
FWIW:
In fact 2 "8 ohms windings" in parallel, are still 8 ohms total (you are keeping turns ratio, hence impedance ratio).
Only advantage (and it's something useful) is that DC resiatance will be halved .... but that's something else.
Wire said "8 ohms" secondaries in series and now you have a 32 ohms output.
Well, I do rewind them .
What's funny is that *often* I find errors, such as the 8 ohms tap not having exactly 1.4X the turns of the 4 ohms one, but as much as 20% more or less turns, which is inexcusable.
Errors up to 40% impedance 😱
I attribute that to the antiscientific mentality so prevalent in this trade, mojo and all that jazz.
As in: somebody has a "killer VOX AC 30" .... the OT burns into a carbonized mess .... some Tech rewinds it, counts turns (wrong ... remember he's pulling crumbling fine wire with tweezers out of it) ... and saves the "magic formula" in his notebook .
And on and on and on.
But wouldn't he *calculate* it and notice it's wrong?
Even something as crude as matching turns ratio to expected impedances?
What for?
After all, it's the way Leo
Jim
Everett
did it
But ... did they?
two 8 ohm windings, in parallel to give 4 ohms, or in series to give 16 ohms.
Check winding details of valve output transformers, same number of turns from 0-8 ohms as 8-16 ohms.
What for?
But ... did they?
