Hi, I'm not sure this can be done but came here for the answer. I want to build a 2 x12 cabinet. The feed to the cabinet would be 8ohm from my guitar amps ext. speaker out.
At times I would like to run one speaker only as I have a lower powered amp 10 watts. Other times it would be both speakers running. I'm not sure I can make this happen due to ohms and wiring issues. I would accept it if I need a switch on the back.
Any help/suggestion would be greatly appreciated
Bboy
Bboy
What ohms can your amp take ?? is it tube or solid state ?? what are the ohmage of your speakers ??
yes more info is needed to answer.
But why do you only want to drive just one of th two speakers? There's no advantage unless you low power amp can only drive 8ohms while you high power amp needs 4ohms.
In this case a switch can parallel in the second speaker but you'll need to check the switch setting every time! Major PITA and likely to cause problems.
Simple is best🙂
Simple is best🙂
Hi, the amps put out 8ohm, The speaker is 8ohm. The reason for the single 12 is that the smaller watt amps probably would not be able to drive both speakers and sound good. The amps are tube and solid state.
Bboy
Bboy
I think there isn"t much you can do .... if your amp ran at 4 ohms you could run one speaker at 8 ohms for half the power and Paralell to 4 ohms for full power ....
I guess you can run one speaker at 8ohms for full power and Series 2 speakers for half the power ....
Most guitar amps and speakers are pretty robust and tolerate mild impedence mismatches well. Also, the amps are usually designed to tolerate being driven hard, so I wouldn't let the fact that you have a fairly low wattage output stop you from using 2 speakers together. The most elegant and highest output solution is to get two 16 ohm speakers and connect them in parallel to provide a total load of 8 ohms. If you already have an 8 ohm speaker you were planning to use then you'd probably get the most output just using the one.
Hi, thanks for the different slant on the topic. I had not thought of using 16ohm speakers for a better sound. The speakers are Cannibis rex by Emminence.
Bboy
Bboy
- Live Sound
- Instruments and Amps
- Guitar Cabinet wiring question
