Guitar amp picks up radio??
OK, I built this amp(3-4 weeks ago), Nice little PP EL84 job. Put a rather simple 12AX7 prestage. Tested it at 2 locations, Here at my house with a 80's Fender Strat with Fender lace sensors &
Tested it at my brothers about 40 miles away with His Carvin with humbuckers.
SWEET little jewel of an amp. Lovely responses and very sharp presence. Makes a Strat come close to The Old Rickembacker/Vox Combo of yesteryear.
Now the weird part,
Its at a new location several hundred miles away now, The claim is it picks up radio stations with his telecaster deluxe?
Schematic
Could this be a product of poor internal shielding on the axe? Or perhaps I need to add a grid stopper?
Gene
Now the weird part,
Schematic
Gene
Try 10K to 47K, in series with the first grid, as CLOSE as possible to the socket. That is the main thing different from the old-reliable plans.
Use a shield on the first tube. If that is a pain, wrap it in tinfoil and use a jumper to ground it: if that cures the problem, get a proper tube shield.
When I grew up there was a 10KW AM radio station about 1 block away from my house. Their elevator music came out of almost every audio device in the house, including the telephone. Guitar amps are a particular problem because you are plugging an antenna (the cord and the guitar) into the input.
Things to try:
1) A different cord. Any corrosion on the cord, jacks, or in the guitar could rectify an AM signal. See if the loudness of the radio music changes when the plug is twisted at the amp and at the guitar.
2) A different guitar. If the new owner can borrow a different guitar it would help isolate the source of the signal. Some guitars are shielded better than others. If it is guitar related the internal shielding may need improvement.
3) If amp modification is needed, a grid stopper would definitely be a good place to start. Check the input jacks for any sign of corrosion or rust. A small capacitor (about 500pF) from the grid to ground of the first tube may help. Make sure that all wiring to the input jacks is short. Shielded cable may be needed.
In my extreme case I had to put a parallel resonant circuit (known among old radio people as a wave trap) inside the amp in series with the input. It must be tuned to the ofending frequency.
Things to try:
This I highly suspect.2) A different guitar. If the new owner can borrow a different guitar it would help isolate the source of the signal. Some guitars are shielded better than others. If it is guitar related the internal shielding may need improvement.
The distance from the input jack to the tube is 1/4 inch from each end of the cap inline to the tube. The Jacks are brand new so I kind of think seeing as other guitars never had this issue, I can most likely rule that out.
Dont think I could get much shorter leads than this 🙂
Most Fenders are known for fairly poor shielding, Combine that with single coil pickups on a telecaster+ high gain factors from the amp, I guess its possible its just his location combined with this amp and his guitar.
Hopefully the grid stopper will fix her up (fingers crossed) I'll know later today .
Gene
Besides better shielding (important), a bad solder joint causes rectification which is a low level AM radio detector circuit.
Problem appartently has solved itself.
Well ok, Sort of.
Switched guitars at his location and no more radio.
So, as it turns out, this particular guitar has less than perfect shielding and a couple other issues, Bad pots, Of course The legendary fender wiggle to work switch and compound that with his home being rather close to a local tower. Go Figure.
I guess I should have known better than to think it was anything different.
Gene
Well ok, Sort of.
Gene
I have this problem with a small 5W guitar tube amp I built around 2 weeks ago. when you crank yhe gain up you can hear what seems to be a spanish Am station from my house and a french AM station from my friends house (It's funny because I live in Spain, 250 miles away from the french border, in a straight line). The amp does this even if the cable is unplugged, It actually sound the same with or without a cable. I tried to correct this by soldering a 47nF cap I had laying around from the input to ground and and giving the "input" shielded cable a turn around 2 ferrite ring I also had laying around. This did nothing to the radio signal (but it did tame most of the hum and the hiss in the amp). It apears to me that the signal is being picked up somewhere "inside" the amp. Is there anything I can do to get rid ofr it? Will a grid stopper resistor do the trick?
Thank you for the input.
You shoudl definitely sue grid stoppers, you can also add additional capacitance to Cin + Cmiller, depending on what your amplifier looks like now (schematic ?). Be careful not to cut to deep with the LP filter these compose.
Often a ferrite on the power cord and the input line will help. If it's solid state, on the speaker leads as well.
A small ceramic capacitor on the grid(s) of the output stage, and on the tone/volume controls may help.
If you know an old time ham radio operator, he may have some suggestions, as this was a common problem back in the day.
I've had this problem with my Rickenbaker 4001 which had singe coil pickups. Nothing like Mariachi music coming through the PA loud and clear. Never mind the ding-dongs behind the mixing board.
This is one nice thing about humbucker pickups on guitars. They cancel out RF interference. Most Fender Stratocasters have single coil pickups although I do think you can get stacked humbuckers in some cases.
Just a thought, probably not a solution.
I just discovered something new regarding my french AM station: I only pick up that station at night, when AM travels better and when I play my bass, on my solid state amp, the amp doen't pick up the station. The guitar tube amp does, but it is quite faint, even at full gain. When plugging in the guitar cable, the tube amp doenst experience a change in the station's "intensity" but when I plug in my bass into my bass amp, the bass amp still doesnt pick up the station but the tube amp's radio noise gets louder and clearer. I now belive that the noise travels trough the cable (antena), into the bass amp, from there to ground and as ground is a common point to both amps, the tube amp picks up the signal through ground! Am I wrong? and if not, how can I prevent this?
Embrace it! I build guitar pedals, and have learned that ANY distortion (even maxxon, boss etc.) will pick up am radio when the gain is very high. I can choose what I would like to listen to between songs by switching pedals. Marshall blues breakers particularly like romanian stations it seems... boss seem to choose english.
- Live Sound
- Instruments and Amps
- Guitar amp picks up radio??
