Guess this mystery woofer!!!
Hi guys,
I saw a pair of these from an electronics surplus store recently and decided to buy them as they might be good stuff. They were real cheap too. Here's what i know or guessed.
310mm Diameter
Die cast Basket
15-20mm max excursion
13lbs overall weight
2" voice coil
Ported pole piece with some cheesy wire grid covering port
Approx 3yrs NOS so probably not chinese or taiwanese.
I was hoping u guys might recognise it, if not, no biggie. Always wanted to try open baffle bass like the H shaped enclosure Linkwitz designed. ;)
Hi guys,
I wanted to do a physical measurement of the driver and referred to Madisound's NHT page to see what needs measuring. To my surprise its very very similar to that woofer! This woofer tho doesn't not have a curved cone and has a foam piece stuck on the cone where the voice coil wires might hit the cone...
Now i just need to see a picture of the back of the woofer just to confirm.
Even if its not, at least i know its from the OEM of NHT1259s...
