Hi I've built boxex for my speakers but now its the moment of truth, putting together my x-overs. before I lay the cct down on some thind mdf, just a few quetions
1.How should I bond the components to the board so they don't fall of, is carpenters glue fine?
2.What guage of wire should I use to connect the CCT, here are the terminals I'm using http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=260-300
I'm not sure if I should use anything under 12 guage, or if there's a rule I should follow or what
3.For connecting the components, should I just solder connections together?
