GU15 SE amp prototype
Hello, Happy New Tear to all colleagues!
Can you please let me know some more details about the sound? Does it sound like a DH tube (airy and effortlessly)? Did you think about a comparison with 4P1L and/or 6P21S, or maybe even with #45 or 2A3?
From the circuit, I understand Ua is 435 Vdc while the drawn current is only 35mA. Why did you chose this OP?
I saw the docs which were published by Charm from Russian Federation. Do you think getting the tube closer to 19W Pdamax would not be safe?
Thank you very much!
I am not decided to use this tube, I was only trying to find some more interesting DH tubes which may work in audio. To be sincere, I listened to a 6P21S SE, amplifier, to a 4P1L SE and to my 2A3/#45 amplifier. 6P21S, clearly sounds better than a usual indirectly heated penthode or tetrode, but not that refined as #45 does. 4P1L is much closer to the triode DH tubes.
Anyway, if I will find them for a reasonable price, I will take the chance to experiment
Kinda off topic:
Saptemari... from your experience are DH tubes good for balanced circuits or just SE? I know that back in the day, because they did not have the concept of global feedback, only open loop, tubes were made with tighter tolerances then now.
I plan to design and build a balanced DHT preamp/line stage for my OTL monoblocks and I intend to use #26 triodes or 4P1L triode strapped.
Sanatate
@Savu, I am not sure about how tight was the tolerance when talking about soviet tubes. For instance, 6C33C was used in MIG”s and their characteristics are very dispersed.
Anyway, I am quite sure your idea is good. I too want to build a push-pull amp using DH tubes. I only built SE amps until a month ago when I finished a PP amp with the classic EL84. It is sounding nice and the extra power made me think about a DHT PP.
I would suggest using a LM317 as a CCS for the cathodes (if using semiconductors is acceptable to you), like Mr. Heran did here: http://diyaudioprojects.com/Tubes/EL84-Push-Pull/ECC802S-SRPP-EL84-Push-Pull-Tube-Amp-CCS.png
You’ll be able to perfectly balance the current between the two tubes.
Sanatate!
