Biggest problem I have with DIY is the sheet metal,
cases, covers, etc.
Still looking for something decent that doesn't cost
an arm and a leg,
Bob
cases, covers, etc.
an arm and a leg,
Bob
Arrived power transformers.
I expect drawings of chassis from manufacturer this Friday.
Do anybody volunteer to help me to draw PCBs using software?
I got quotes for chassis' made in USA: $195 per chassis (plus shipment).
Who is in please let me know.
Anatoliy
Anatoliy
Cobra2 said:One for me!
Arne K
Arne;
they will be bright red.
I've asked for a quote for some chrome plated, waiting for the answer..
The chassis contains holes for transformers, for 4 GU-50 tubes in thin sockets, for 2x 6N2P + 2 x 6N6P + 2 x 6E1P + one SG3S.
Rear panel: 2 holes for TRS inputs (or RCA may be installed for Hi End version), 6 holes for speakers (4, 8, 16 Ohm for each channels) - TRS (for Gih End Chinese golden-plexiglass bananas may be installed, for 4 and 8 ohm only), 2 fuses (anode and AC), and one AC plug (rectangular).
Front panel: 2 volume controls, 1 power switch, one power lock.
Perforated bottom cover
Also, I will order optional mirrors between GU-50 tubes and transformers, for better look and to protect transformers from IR radiation from tubes and front and rear false - panels with lettering. However, mine will have Wavebourn marked on them, so probably you will need to order some for your taste.
Anatoliy
Hello Wavebourn
Did you order special transformer for these project or stock transformers from Edcor?
Please let me know.
I think It would be more interesting to try these project.
Of course I'm not in hurry, I just study which way to go.
You wrote GU-50 tubes are great.
I found some schematic at German website (That site it have some PC board lay out to..)but the power tube are powered under 400V.
Also I read your project , I like it, you use much higher voltage.
I will wait on your advise. If I invest a lot of money in the irons I want to be sure I can finish the project. Also I will register on your forum.
Cobra did you finished your amp??
First I have to finish some SS project.
Greetings gabor
Please let me know.
Greetings gabor
Wavebourn,
Are all of the transformers spoken for? If someone decides not to take there order please let me know.
Tad
Tad
- Group Buys
- GU-50 100W output and power transformers
