I recently got two of these tubes as a present.
I would like to know what type of socket is needed.
An extensive search on the Internet did not yield any result.
Thanks in advance.
Thanks in advance.
SOCKET
Your tubes require a B8S type socket + two anode caps (no idea what type).
More data can be found here:
ARCOR
And a datasheet:
DOUBLE TRANSMITTING TETRODE
Cheers,😉
ARCOR
And a datasheet:
Cheers,😉
I notice that the G2 dissapation max (60w) is greater than an anode max (40w).
From what I gather, RF tetrodes will generally accept higher than specified G2 voltage, providing the anode volts are kept down.
So, could this be a good contender for triode connection?
Just conjecture.
I think this is an experimenters tube.
Edit:
He he, just noticed the common G2 between sections. That'll spoil it.
Edit2:
Which is why the dissapation is higher🙄
Just conjecture.
Edit:
Edit2:
WHAT'S IN A NAME.
Glad I could help.
From looking at your name I assume you live in Belgium or France so if you don't mind you have a good chance of finding what you need here:
HALFIN INTL
You can send Mr.Michel Wiams an e-mail or call him directly at this # 02.209.29.01.
Hope it helps,
Cheers,😉
Glad I could help.
HALFIN INTL
Hope it helps,
Cheers,😉
Yes, it helps.
I think the ARCOR site is a treasure.
I will call Mr. Wiams of Halfin and see if he can
supply me with two of these B8S's
Thanks again.
Thanks again.
- Tubes / Valves
- GU-19-1 Russian tube
