Folks,
I have a 300BSE Mk.II (6SN7, EL34, 300B) that instantly trips the breaker when it is turned on.
With the power switch on, I measure 1.6 ohms across the hot and neutral AC pins. There are no shorts between hot/neutral and the ground pin, and the internal fuse F1 on the PCB is not blown.
I am afraid that my power transformer primary may be shorted. Can someone ohm out their unit and confirm my measurements?
TIA,
-- josé k.
jose_korneluk AT bellsouth.net
TIA,
-- josé k.
