I want to install gspeakers on my pc with linux ubunty 7.04. Tried several times, no result. Can anyone help me guide me through the process?
Thanks!
Thanks!
Thanks for reply Rastafazz
Here is instruction page:http://gspeakers.sourceforge.net/doc/gspeakers-gtk2/linuxinstall.html
First i begin as suggested with spice install. Putted spice3f5sfix.tar.gz (/home/jw/Desktop/spice3f5sfix.tar.gz_FILES ) on desktop
Then in terminal:
jw@Pentium1800:~$ ./util/build linux install
bash: ./util/build: No such file or directory
I have send a mail to the mailadress in Sweden, it came back.
Then in terminal:
I think you have forget to untar the archive or go to spice directory.
Here are all the steps.
go into the directory where you've downloaded spice3f5sfix.tar.gz (cd directory_name)
i will assume it is spice here
and run to following
cd spice
tar xvzf spice3f5sfix.tar.gz
cd spice3f5sfix
./util/build linux
let me know how it goes.
--stephan
ps: if you can't go to the right directory
add this three commands and start again from cd spice
wget http://www.ibiblio.org/pub/Linux/apps/spice3f5sfix.tar.gz
mkdir spice
cp spice3f5sfix.tar.gz spice/
cd spice
cd spice3f5sfix
./util/build linux
--stephan
mkdir spice
Well, it was some work, also for the machine😀 Never seen in term. something lasting that long. Think i have spice now, saw btw errors coming along. Can i check if i have spice?
These are the few last lines in terminal: (post all will diyaudio's site allmost explode!)I saved the whole in an editer forpossible referral
make[3]: *** [multidec.o] Error 1
make[3]: Target `recursive' not remade because of errors.
make[3]: Leaving directory `/home/jw/Desktop/spice3f5sfix/obj/bin'
Done with spice3f5sfix/src
make[2]: Leaving directory `/home/jw/Desktop/spice3f5sfix/obj'
make[1]: Leaving directory `/home/jw/Desktop/spice3f5sfix'
Done with build at wo okt 10 19:32:02 CEST 2007
jw@Pentium1800:~/Desktop/spice3f5sfix$
The wget didn't work, he could not find package (even after he found site)
No, spice won't work.
It seems that libtermcap is missing.
Let me check which package has it.
--stephan
--stephan
Hi again,
Compiling spice seems to need more than just libtermcap.
There is an easier way. I've tried it on my machine and it seems to be ok: gpeakers launched successfully and it could have a curve.
You need to install these packages if you don't have them already
libxml2-dev
libgtkmm-2.4-dev
automake1.7
gnucap
then download gspeakers
tar xvzf gspeakers-0.11.tar.gz
cd gspeakers-0.11
./configure
make
sudo make install
and then
gspeakers to run it.
Let me know if you have any problem with this.
--stephan
libxml2-dev
libgtkmm-2.4-dev
automake1.7
gnucap
cd gspeakers-0.11
./configure
make
sudo make install
and then
--stephan
Thank you for helping me on the way Stephan, it's allmost done i guess.
First i checked in synaptic and added libgtkmm-2.4-dev and automake1.7, rest i had allready.
With gspeakers install he missed some other applications:
jw@Pentium1800:~$ cd /home/jw/Desktop/gspeakers-0.11
jw@Pentium1800:~/Desktop/gspeakers-0.11$ ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking for C++ compiler default output... configure: error: C++ compiler cannot create executables
See `config.log' for more details.
Btw i copied-pasted gspeakers-0.11 from desktop, and removed the ¨, and enter. This is the way i learned here: http://monkeyblog.org/ubuntu/installing/
C++ misses, and i think all the 'no' answered items are from spice, but not sure.
you need to install g++ packages to be able to compile
or if you want to make thing easier i can send you a precompiled package.
ps: if you install gnucap you don't need to compile the other spice package.
I didn't succeed, i think first to install spice again, gspeakers seeks for crossover items in terminal
I will be away for a week.
if you have installed gnucap with the package manager , you won't the other spice package.
pm me your email address and i will make a precompiled gspeakers for you.
--stephan
--stephan
You can get the precompiled package here : http://rastafazz.googlepages.com/
then do
tar xvzf gspeakers-0.11_compiled.tar.gz
cd gspeakers-0.11
cd src
./gspeakers &
before this you need to have
libgtkmm-2.4 and gnucap.
to compile yourself you need to install g++ package (and the ones i've mentionned in the previous post (post 7))
i've tried on a fresh installed machine.
--stephan
then do
cd gspeakers-0.11
cd src
./gspeakers &
--stephan
Have it on 2 machines now. Thanks a lot Stephan.
Btw can i make a faster executor to load it instead of in terminal?
- gspeakers install
