Grundig cd 7550 problems
Hi to all.
I've some problems with a cd 7550..but i can't solve and understand what happent.
The player doesn't read the TOC i suppose, because after pushing play..it start to spin but stops after few seconds..without disc error on display.
I tried to start the service loop A but..it doesn't start..
I already fixed with a tinned wire the ground griplets on the the pcbs.
Checking some voltages, i found that on the connectos 23 on servo pcb (cdm power supply i suppose), the VC is almos at 0.5 volts.
Unfortunately on the service manual i could not find with tensions i've to read on connector N. 3..referred to turntable..focus..and radial motor.
Anyone knows with tension i've to read on 23 connector from Servo PCB?
Thanks to anyone will helo me.
Maurizio.
