GRS 8FR-8?
AkAbak is the most flexible AFAIK. Most use HR because it's quick/easy and has most types of alignments or can be kludged for some oddballs such as the B0$3 Wave Cannon once one is familiar with its various options.
GM
GM, I had searched Google for diy designs with this driver and noticed there were quite a few BVR builds. I’ve never listened to one personally, but I really like the aesthetic of them. How would you characterize their sound?
Done right, sounds like what they are, truncated BLHs designed to offset baffle step diffraction [BSC]. If you haven't ever auditioned a BLH, then the closest I can come would be likened to a wide band, low tuned system loaded with large, high Vas, low Qt drivers.
GM
I've had BG20 in a "K12" Karlson and in one of my fake Druid pipes (did not use the tweeter which went with Eminence's old B102) If adding a tweeter, other folks graphs show some smoothing of BG20's top by removing the whizzer. I just put a bit of bonded Dacron between the whizzer and main cone.
That’s a great looking design, Freddi. I appreciate the advice, but I’d really like to maintain the bicone/whizzer aesthetic, it’s a big draw for me. I think I mentioned it above, but several of the designs I found on the web have schematics for a notch filter that does a really good job of smoothing the top end. I’m not above using DSP, either, and I’m planning on getting one of the Dayton 4x8 units, anyway.
I’m on the BVR/BLH/MLTL/TQWT train now, which would you suggest from a balanced user friendly/flexibility standpoint?
HR and/or Leonard Audio's TL: http://www.diyaudio.com/forums/soft...n-line-modelling-software-17.html#post5160274
Help File | Leonard Audio
If you haven't already scoped it out, MJK's site is TL/horn 'central' for your specific 'train', though requires older versions of MathCad and not quite as 'friendly', though has an active/helpful yahoo Group: Quarter Wavelength Loudspeaker Design
GM
"here's" a set of parameters perhaps resonable - this looks like the GRS BOFU
NEW 8" Extended Range Speaker.whizzer tweeter cone.8ohm.Replacement Woofer.8inch | eBay
if those specs are right then it could be used in a 3rd order sealed box to reduce box size, "boost" low end, and flatten response
here's a sim at 35 liters and ~375uF series cap. To work, it needs to be driven by a low source impedance amp (the usual solid state amp)
my poor old (15+ yrs) pc can't even run "paint" at this point so no screen shot
- but here's what WT3 says with no break-in - I'll try running it in for a while and get a vas. I'm not sure about my WT3 calibration a few minutes ago being "on" so will re-calibrate later - assume its "ballpark"
The whizzer is glued on - or made - so tilts a few degrees from perfect. GRS's magnet backpiece is un-vented (might a dustcap vent be helpful ?) - the magnet's stray field and at the backplate has very little "pull" compared to lower q motors of the same size.
it doesn't look too terrible
Re = 8.05, fs = 58.54Hz, qts = 0.7335, qes = 0.855 (might be 0.835 ? - can't read my own writing) qms = 5.162, Le = 0.8382mH
so plausible that qts could be around 0.63 IF fs drops to 53Hz as in one Parts Express view.
if that cheap MCM meets spec them would be a good way to go. I somehow feel Newark's lower prices may mean once they're gone they're really gone (?)
~10 % seems plausible without tweaking the spider, but at least it's not as high as some........
Yeah, kind of my thought too, so have been debating about just buying a bunch of these now rather than go through the hassle/cost of re-coning the B20s later.
GM
I don't think fs will drop a lot but have it on a 6.3vac filament transformer - that's roughly 5 watts and excursion looks maybe 5-6mm p-p in free air. Some harmonics at that drive level. How long would you run it at this voltage/60Hz ?
