A reminder.....Sunday 15th September is the last day to sign up and pay.
No. Have you checked the pcb layout? There you can see how the pcb look like.
No need to, now. Still looking for boards that will allow for option to use dual bridges and keep grounds separate, if desired. Thanks.
Mine arrived as well. Is the a example BOM somewhere? At least with the level of saying which components are optional, which do depend on the output voltage and which are anyway similar?
Go to the wiki page. There you can find some useful links. If you want any special output voltages I make a new variant and add it in the pdf file.
Ah, found the PDF. I'm about to use it for a head phone amplifier that would take anything between +/- 9 V and +/- 18 V. I'd prefer the 18 V option there.
I hope that it would be possible to reach 18 V with just a little modifications on the 15 V variant, like change of the resistors. If not, then I settle with the 15 V variant.
In case you have enough space, what's the best choice - 4 big FM caps of 10,000 mF each or many small FMs?
- Group Buys
- Group Buy: SSR03 Super Regulator Power Supply
