Hi. I really want to build up a small bookshelf speaker with Sb acoustics Satori drivers.
My plan is to produce the baffles with the waveguide machined into the baffle made of solid Richlite, and for either the 6.5” satori or 7.5” mid/woofer as one piece.
A single sheet would yield a lot of baffles and the unit cost wouldn’t be huge. And probably less than the aluminium waveguides that are currently sold with the high end SB tweeters. But the initial outlay for the 18-20mm sheet and double machining is fairly high.
So seeing if anyone wants to share the cost in a group buy.
If anyone is keen let me know.
