The US$ pricing at Jaycar is half that of the posting from Electus Distributors.grege said:I believe Electus Distribution is Jaycar's distributor so you get exactly the same product for less if you have a ABN. (Australian Business Number)
http://www1.electusdistribution.com...ords=&CATID=34&SUBCATID=170&form=CAT&SPECIAL=
Could you find out what shipping options cost to the US?
Regarding the Alpha pot that I use,
It looks like Sherman, in his moded SI digital amp, use the same pot as mine:
http://www.diyaudio.com/forums/showthread.php?postid=550012#post550012
So it must be available in US as well.
Give it a try... when you able to found it...
REgards,
David
REgards,
David
I looks like it would be significantly cheaper for me to buy from Jaycar US?
You don't get the real prices until you have a Electus account. I can't imagine the prices actually being better than the US prices plus the postage would be significant.
Funny about those prices and the Jaycar US prices being so much cheaper, I noticed that too a while ago, emailed them about it. via the Australian email and the New Zealand one, no reply.
Considering Jaycar is an Australian company and all. Maybe there suppliers are US? but judging by the prices it looks like they've never changed the exchange conversion rate on their site since over 2 years ago.
Let me know if you manage to order via the US site to get it delivered to an Australian address, they don't seem to allow it, insisting you go to your regional site.
You would think going through Electus Distribution would be even cheaper than the US 100+ quantity Jaycar price. Which reminds me I should really get an account with Electus.
I'd be in on any group buy of pots around the sub $20 USD price range.
![xeye :xeye: :xeye:](https://files.diyaudio.com/forums/images/smilies/xeye.gif)
I was nosing around Jaycar site and found they're prefered shipping method for international is Fedex airmail. So off to Fedex I went, I plugged in Jaycar's zipcode and mine. Your not going to like this. A 10 pound 9"x12"x8" package is nearly $200 USD. The component final pricing would need to be adjusted due to shipping cost yet would still be very reasonable.grege said:
On the good side, We could get a hugh amount of small stuff in a package that size.
100 - misc. 9mm dual gang log/linear pots
100 - misc. 16mm dual gang log/linear pots
100 - misc. multi turn trimpots
100 - 40 pin dual inline jumpers
100 - 2way PCB mount screw terminals
100 - 3way PCB mount screw terminals
100 - 5amp 12way screw terminal strips
100 - 10amp 12way screw terminal strips
200 - misc 3mm and 5mm led's and clips
These are just a few items that I thought would be a good group buy. What items would everyone else like to see in a buy.
Phil
Australia's international shipping cost are sharply changed by weight and package size. Jaycar states final delivered costs will not be determined until packaged. So I guess we play roulette on final adjusted part costs to group buy participants.
I still think the final pricing will be reasonable. Anyone think not!
Phil
10k audio log dual pot
Get some Alps 10k dual audio log surplus(new old stock) motor run on 5 to9 vdc (if needed). Use two for balanced,for a 20k: go for a quality resistor in serie(15k-20k) and this pot across.
Only 12$ each, take 20 for 10$ each,take 50 for 9$ each and take
100 for 8$ each. Non inductive resistors 15k at 1.50$ each. Also lot of dual pot dual shaft 50k ,100k alps new old stock .
Here a pic of Harman Kardon preamp board. The two pots on right are quad with dual shaft .The value is 50k(Alps made in Japan).The left one is quad but single shaft 100k,the last one is
the balance 50k linear. Price 30$ with knobs,24$ without,have very few boards with.
For those interested in a 25k PEC concentric shaft carbon pot for around $27 please
sign up on the WIKI:
http://www.diyaudio.com/wiki/index.php?page=PEC+Carbon+Potentiometer+Group+Buy
This is only to show interest, not a promise to buy!
This thread is a bit dated, I don't know if anyone is still interested in a sub $20 solution. I found 24mm Taiwan Alpha dual ganged 10K and 50K audio taper pots on mouser.com. They cost $1.96 each in quantities of 10+. Sounds like a good deal.
http://www.mouser.com/catalog/621/452.pdf
The pots on p. 452 aren't claimed to be carbon. Except for the wirewound ones, it doesn't say what they are as far as I can tell.
On p. 451, there are 17mm carbon pots with silver contacts. These are the only ones that are stated to be what we want, but don't come dual.
However, in general, dual carbon pots don't seem to track between channels as well as othe types, so maybe one knob for each channel is what we are stuck with.....
- Group Buys
- Group Buy: High quality pots
