Why would this work better than a simple resistor and capacitor? I understand the role of the capacitor, which I would also include.
But the diodes? What does he mean by a "major problem"?
I think the resistor value shown is actually a little too low. I would still stick to something in the region of 30-100 ohms.
The diodes are there to limit the voltage across the resistor in the event of a short circuit to the chassis. Without the diodes, the resistor would blow and you'd end up with a 'hot' chassis. With the diodes in place, the diodes conduct when the ground current causes the voltage drop across the resistor to increase beyond two diode drops (1.5~2 V). This will cause significant current to flow and blow the mains fuse or circuit breaker.
~Tom
what should the rating be for the resistor? I've been using 10R 1W per different soundwesthost article. the one in this post says 5W wirewound.
I have not used the diodes and probably will add them from now on.
The diodes are much safer than a resistor alone. Even if the diode is not quite adequate, and it fails, it will fail short. The resistor will fail open. So use nice fat diodes (you can use a cheap 20W bridge). Then, if you want to use a resistor too, it can be a regular 1.4W part.
Sheldon
