Grounding block?
Depends on how you do it.
Since the material is stainless steel I would avoid running high current through it, so loudspeaker ground should be routed to PS ground and then with a single wire to this grounding block. Same with signal ground. From input connector to signal board ground and then with a single wire to grounding block.
Just to avoid current sourced interference between grounding points.
Reactions: Mulburg
