thats right. chip B's output is connected to ground directly, shifting the power supply (that has no reference to ground) so that the output can effectively swing the full supply voltage in both positive and negative directions. a good explaination of this topology can be found here:
http://www.crownaudio.com/pdf/amps/grbgpapr.pdf
Sunn had used this output configuration in their Concert series power amplifiers before Crown did, I believe.
I had just posted this earlier, But I had to delete it because the link was to a revised version and I think that it was incorrect.
This is the correct print to the two versions I have of this amplifier in which are slave amplifiers.
http://sunn.ampage.org/site/schematics/concertbass.gif
enjoy !!
jer 🙂
enjoy !!
jer 🙂
you're right that seems like being the same design, altough its obviously transformer-coupled(?)
anyway, does my implemention of that design using lm4780s work? using ne5532 as opamp instead of lm4780s works properly, but into very little load of course. so the only problem i see are the protection circuits in the chip.
The output devices are driven by a transformer,But the output devices are configured as bridged and ground on one end.
It took me a long time to realize how this configuration worked ,But it is very simple really.
If it works with a regular low power opamp I see no reason that it wouldn't work with a power opamp.
Is the input ground Referenced to GND?
jer 🙂
jer 🙂
my guess is that you need to look at stability, the power chip amps are only stable for Acl > 10
some Spice macromodels will fail by showing stable operation when the circuit isn't
you may need "noise gain" compensation added to the "gnd" amp
and I hate it when people don't just put the image in their post instead of linking a pdf
- Chip Amps
- Grounded Bridge Chipamp (using LM4780)
