Hi all!
I have been working on the amplifier for a couple of days and have a problem with starting it "cold" as soon as I turn it off. Starting it for 5-6 seconds wouldn't oscillate twice out of ten. if it has a final stage (IRFP360LC) then it will unfortunately shoot you.
I have already replaced IR2113 on it. If you go then you can unwind completely, do not collapse. What can cause it?
https://im9.cz/sk/iR/importprodukt-orig/cc1/cc145ef3c246461aebb669e5334fb2bf.jpg
It won't be the driver it will be the NAND gates not having enough dead time.
Without a schematic, not a lot more I can guess on.
It has been tested with a 14v 43A power supply with adjustable current limit. I simply turn on / off with Remote
- Class D
- Ground Zero PLUTONIUM GZPA 1.8000D Blowing output fets random
