This preamp board has a "GRN" connection between the + and - on each channel. I understand that this is connected to a chassis. But I am only going to mount the board either on a board or in a plastic chassis, so do I need to wire this to anything? Photo attached. Thanks!
The DC supply will only have +and - output connectors. Do you mean shielding on the interconnect cables from the preamp to the amp? And how would I access those? Thanks.
Thanks but I am using rca outputs. Does this mean I HAVE to use xlr? Is there way around this, I'd rather use RCA for the sake of simplicity... thanks
- Analog Line Level
- "Ground" connection on preamp board
