grid chokes
Tim, there are actually some benefits to using a grid choke. All tubes have a fractional amount of leakage current in the "grid circuit". The big old triodes have a bit more, and so you'll often see a limitation on grid DCR - and you'll see two numbers, one for self bias, and one for fixed - the value for fixed being a fifth lower usually. This is because in the self bias situation the tube can compensate for any change in it's grid-cathode voltage relationship, whereas in the fixed situation - it can't.
You might ask, what's the big deal? Well, even a small leakage across 1 meg can shift the bias enough to cause problems.
So.... we can use a choke between the grid and ground instead, and those teeny tiny currents will only see a few thousand ohms, instead of 500k, etc. Of course the AC signal sees the inductance of the choke as a high resistance, and away we go!
Make sense?
A Hammond 156C is a cheap $10 way to try them out for yourself.:nod:
The Hammond 156C as a grid choke?
Most applications I've seen use a billion billion henrys. Overkill?
I've been too lazy to do the design work required to become familiar with grid chokes, but I have some 156C's and it would be great if I can use them with some type 50's in S.E.
Make sense?
