Graphite ring on sweep tubes
Disabled Account
Joined 2010
Just a quick question..
What was the graphite ring (looked like aquadag..a line that went around the tube base about half an inch up the bottle) that was put on the outside of glass on some sweep tubes for?
I have seen them arc across it..I can't find any pictures and I am sure it was connected to one of the pins on the bottom of the tube..
Curiostiy has the beter of me again 🙂
I think this is close:
http://www.google.co.uk/imgres?q=pl...41&tbnw=59&start=0&ndsp=35&ved=1t:429,r:9,s:0
M. Gregg
In the EL502 ( which is similar to EL504 ) this ring is connected to pin 9 .
mississippi, I don't quite understand the dc aspect you are referring to?
The characteristic of a sweep application that stands out from the crowd is the short high voltage flyback transient - which to my mind would be the reason for extra shielding, rather than the high duty cycle low voltage conduction period (which is perhaps the DC aspect you are referring to?)
Ciao, Tim
Barkhausen oscillation or BK as we called it, manifested itself on some Televisions as a thin vertical stripe of white dots. We used to wrap a single shorted turn of tinned copper wire on the outside of the sweep output tube, take the loop down to a ground point, then adjust the wire loop up and down the tube for minimum interference. Later tubes came with the graphite ring already located inside it as it was becoming a common problem in its day with certain makes of Televisions. I doubt if BK would be a problem with normal audio usage though.
My understanding of BK is it's due to electrode construction; early sweeps, when the plate voltage pulls down below the screen, effectively created a backward wave oscillator between cathode current and secondary emission from the plate as it bounces in the plate-to-screen cavity. The suppressor grid plays an important role here, as biasing it moderately destabilizes the situation.
Tim
I have a fair number of 18GB5s (LL500, I believe) that have the stripe (some don't). The ones that have the stripe (graphite or a green band) are generally made in Holland or Japan. I haven't seen the ring on any of my US-made sweep tubes.
Ciao, Tim
The DC voltage on the plate, will charge the glas bulb. This charge will affect
the the other grids whose wires are at the bottum of the bulb.
Just for interest,
I have seen under fault conditions the ring glow "burn" with a blue dot that spread "moved" across the surface of the ring...I am talking on the outside of the glass.. leaving a burn trace mark..
Again I don't know what caused it..just the point was that conduction was taking place at that point..maybe it was some deposit causing a connection to another pin or maybe it was induced... Then again when the tube was changed the effect happened on the replaced one...(circuit condition /fault maybe?) The duff tube worked in another set..
M. Gregg
when television was brought into existence, there was a lot of safety precautions that were not in place. the 2nd anode was exposed. etc. in the 50's x-ray radiation paranoia was high and the total auquadag coating of the crt was introduced, and the shadow mask (one of several advantages of the shadow mask).
the "Barkhausen effect" was more of a tripler tube and yolk resonance thing that capacitor network fixed.
the ring was a safety precaution that was on some sweep tubes because when those tubes failed cause a tremendous release of x-radiation. they were either grounded or though a spark cap. some sweep tube had them on them to alter the inter-electrode capacitance to lower grid emission.
Some history
X-rays emanate at an angle from the rear of the target, so little would out of the front of the CRT.
Aquadag was there to produce a capacitor to smooth the final anode voltage.
Protection from CRT generated X-rays was achieved mainly by lead-loaded glass.
X-radiation only occurs at voltages exceeding 25KV, thus it wasn't a problem until colour TV came along, except for projection TV's.
The major X-ray generator in valve TV's was the shunt regulator (European type eg PD500) which was always screened.
I have never heard of X-ray emanation from a "sweep tube". Please explain the mechanism.
