GR REASEARCH(AlphaLS)
chris haberland said:
GR RESEARCH ALPHA LS
Chris,
could you unset your caps-lock key. Typing in all CAPs is considered to be yelling (and is really hard to read).
I haven't heard these GRs but have heard a small set of 2-ways that were quite good.
The Line looks interesting, and knowing GR is probably well sorted out. I have met Bob at Creative and will do business with him sometime -- he carries some nice product.
You should have a run thru Tom's Line Array to get some background. This thread has a couple posts pointing to two excellent technical papers on the subject of line arrays.
Line arrays are facinating, but one has to consider the trade-off of many lowe cost drivers vrs spending the same money on fewer high quality drivers.
In either case going active is always a good idea.
dave
Hi Chris,
I have heard a similar line array recently. It was using a line of the same BG ribbons, but different woofers Peerless 6.5" HDS. I liked it, the midrange was very smooth and sweet. Line arrays have a wonderful, big sound, with a broad soundstage. The are also very dynamic, being extremely efficent. The one I heard had the ribbons used in a dipole fashion, so that would be different. I think the very highest registers were a bit thin.
I have taken a slightly different approach myself. I am building a variant of the Linus Line array, with modifications.
Interestingly, the Linus array was undertaken after the creators listened to the Alpha LS prototype. It is a small DIY world.
Do be sure to read the Linus White Paper by Jim Griffin. There is a link on my webpage. Good stuff.
What is your budget and what exactly are you trying to accomplish?
James
