if you are in repair amp or tray to build nice amp and other like preamp ...you should have good oscope . digital oscilloscope can help see and studying on signal .we inject signal to input and see result on small color tft.
after buy new one you need time to learn how it works and how protect this oscop ?
i used gds-122 frome goodwill instek. 6 weeks before when i pushed power key ...i heard noise from inside and became hot😕
i found one 8 pin smd mosfet on goodwill oscope pcb.this is output of series regulator circuit .if this mosfet is damaged complete voltage of battery goes to 3.3 vcc line 😱
there is no fuse and zener .
please look at the circuit for ovp and protect other parts. 16 v zener can protect 12 v lin .
for saving 3.3 v ve can use 4.1 v zener .
suppose you have transistor radio with battery power.if output transistor damage and no sound in speaker .there is one question.how transistor was damaged?
quality of transistor ....?
kind of music?
kind of battery?
life of transistor ?
kind of music?
kind of battery?
hooman you have reported this thread five time now. The title has been changed from goodwill instek digital scope to Goodwill Instek digital oscilloscope as you asked.
thanks ....
yes i asked for changing title .thanks
goodwill used in gds-122 fpga ic from exlinx.
Spartan-6 FPGA DC Characteristics
89
Spartan-6 FPGA Data Sheet:
DC and Switching Characteristics
VCCINT Internal supply voltage relative to GND –0.5 to 1.32 V
VCCAUX Auxiliary supply voltage relative to GND –0.5 to 3.75 V
VCCO Output drivers supply voltage relative to GND –0.5 to 3.75 V
VBATT Key memory battery backup supply (LX75, LX75T, LX100, LX100T, LX150, and LX150T only) –0.5 to 4.05 V
VFS
after shorting mosfet in series regulator .... 7.5 v of battery damaged the fpga ic .....and getting hot very quickly.
Its toast and replacing it will be a major challenge without the special equipment needed.
thanks for replay but i am working in sony service and can replace this kind ic simply but good will never answer to me .i send this oscop to goodwill service center in my country .they can just changing battery😡
repair by component is true service .
there is risk for digital oscope after warranty period if buy from company like goodwill.
never soldering on main board ...but seems some ic has re soldering . with goodwill human mistek in series regulator design ...my oscop not turn on .
goodwill dont want to help me .🙁
i tray to fix problem .for this defect oscop factory should send fpga ... need soft ware ..this fpga not expensive .
- Design & Build
- Equipment & Tools
- Goodwill Instek digital oscilloscope
